Zyxel – Multy M1 - problems with wifi connection
b46664
Please, I need a help.
I have Zyxel – Multy M1 and all my devices which are connected to it with a wifi, regularly are loosing wifi (they are 2 meter far from the router). I have found something about "logging" in my router settings and I have no idea what does it mean.
Thank you for your help!
Hi @b46664
As the log shows, the internet seems disconnected every 9 minutes on Nov 15th.
Please check your ethernet cable connect correctly, or try with another cable.
Please send us feedback on the Multy APP.
The Enabled logging on this page means recording the log on Multy M1, if you disable it, there would be no logs show on this page.
- 244 Nebula Ideas
- 6.9K Security
- 798 USG FLEX H Series
- 391 Security Ideas
- 88 Switch Ideas
- 59 Wireless Ideas
- 7.3K Consumer Product
- 327 Service & License
- 531 News and Release
- 104 Security Advisories
- 5.4K FAQ
- 91 About Community
- 124 Security Highlight
