LTE2566 Firmware bugs
JimTruss
Hello everybody. My questions are 2, and connected.
Why there is not an option to reset the data usage counters whenever you need, but only the option to set a reset date?
Why when you try to set manually Date and Time (I tried to set 23:59 in order to reset the above counters, after setting tomorrow as reset date) you cannot set hours between 15 and 23, because after selecting 15, or 16, 17 and so on, the router set 13 instead of 23 or 4 instead of 16 etc.? I think these are firmware bugs, am I right?
Any solution or chance to see a firmware update that corrects these bugs?
I couldn't find a support contact to send these questions to. Only FAQs or dumb virtual assistant.
Any comment and/or suggestions? Thank you in advance
Hello @JimTruss
The Consumer Ideas part of this forum might be a place for these to go.
Do you know what firmware your running?
1.00(ABTW.3)C0 is available at https://www.zyxel.com/global/en/support/download?model=lte2566-m634
Kind regards,
Tony0 -
Thank you Tony.
I already updated the firmware with the version you kindly suggested me. The bugs were still there. I will try to post my question in the other section.
Thank you again. Kind regards, Jim1
- 243 Nebula Ideas
- 6.8K Security
- 781 USG FLEX H Series
- 387 Security Ideas
- 58 Wireless Ideas
- 7.2K Consumer Product
- 324 Service & License
- 527 News and Release
- 101 Security Advisories
- 5.3K FAQ
- 91 About Community
- 121 Security Highlight
