Manuals about Zyxel NR5103E and Zyxel Air App help documents ?
Try this!
NR5103E
is there any was to connect the mode 5103E from three using any zyxel APPS?
Hi @Dsangrereal
According the manual I downloaded from the link that Ayeball posted previously
https://us.v-cdn.net/6029482/uploads/HD22RE2G9XW9/nr-fwa-indor-series-ug-v4-40-ed3-2022-09-08-1.pdf,
you can use the Zyxel Air app, see below:
Kind regards,
Tony0 -
- 244 Nebula Ideas
- 6.9K Security
- 807 USG FLEX H Series
- 392 Security Ideas
- 88 Switch Ideas
- 60 Wireless Ideas
- 7.3K Consumer Product
- 333 Service & License
- 541 News and Release
- 106 Security Advisories
- 5.5K FAQ
- 89 About Community
- 124 Security Highlight
