issue with custom cronjobs and scripts
Hello there
I have an NSA325 v2 I connect to it using ssh and try to set up my custom cronjob and run my custom scripts.
after any reboot, the whole cronjobs and script get removed and I don't know why it's happening! is it something about the Linux version?
is there any way to install something like Debian or red hat on NSA325 v2?
regards
The problem is that the /etc directory in in the initramfs (with exception of /etc/zyxel, on which a flash partition is mounted), and so any change won't survive a reboot.
I wrote a package 'Tweaks', which can add cronjobs (an other goodies), which you can install if you first install MetaRepository.
Yes.
it is possible that the firmware is configured to reset the system to its default state upon reboot. You can try creating a startup script that sets up your custom cronjobs and runs your custom scripts after the system boots up.
- 235 Nebula Ideas
- 6.7K Security
- 734 USG FLEX H Series
- 375 Security Ideas
- 58 Wireless Ideas
- 7.1K Consumer Product
- 319 Service & License
- 511 News and Release
- 99 Security Advisories
- 5.2K FAQ
- 90 About Community
- 117 Security Highlight
