How to resolve WiFi disconnection issues with IoT devices?
1/ Create a new SSID exclusively for the IoT device can take to address this problem effectively.
Navigate to Configure > WiFI SSID settings, type the SSID name and toggle Enabled.
Navigate to Configure > Access point > SSID advanced settings
- Set the security as WPA2 personal is highest (or Open/ WPA1).
- Select "2.4GHz only" for band mode option
- Disable 802.11k/v/r.
2. Disable “Allow 802.11ax/ac/n stations only” function
Go to Configure > Access points > Radio settings
3. Setting the Radio mode to 802.11b/g/n
Go to Configure > Access points > Radio settings > Choose AP with 2.4GHz in the bottom of the page
Moreover, don’t forget to check the distance between the IoT devices and the access point. Walls, floors, and other obstructions can weaken the wireless signal. The IoT device’s connects signal recommended –70dBm or above. We can refer to Clients > Access point clients to check the signal.
Note: Make sure your IoT device and AP are both updated to their latest firmware versions for maximum efficiency and performance.
Zyxel_Judy
- 244 Nebula Ideas
- 6.9K Security
- 805 USG FLEX H Series
- 392 Security Ideas
- 88 Switch Ideas
- 60 Wireless Ideas
- 7.3K Consumer Product
- 332 Service & License
- 540 News and Release
- 106 Security Advisories
- 5.5K FAQ
- 89 About Community
- 124 Security Highlight
