LTE5388-M804: SIP not able to register when in Cellular IP Passthrough (Bridge) mode.
I have a requirement to have the external address hosted on the interface of the downstream firewall (behind the M804) to host services behind the firewall (not the NAT'd internal address).
When the M804 is in Router mode, I can made and receive calls using the voice function and associated SIP account on the unit (telephone attached to the phone port). When I change the Cellular mode to IP Passthrough, the SIP account is unable to register and I am unable to make or receive calls. I can't seem to find any setting that would need to be changed within the GUI to support this.
Is this a supported use case? If not, there needs to be some sort of warning that SIP will stop working once IP Passthrough is activated.
Conceptually, VoIP on the LTE5388-M804 only works under routing mode, it does not work in IP passthrough mode because the LTE5388-M804 already leases the WAN IP address (IP address from the ISP) to the LAN client, in your case it's a firewall.
And in fact it seems to only work in routing mode too.
Regards,
Bob
- 244 Nebula Ideas
- 6.9K Security
- 803 USG FLEX H Series
- 392 Security Ideas
- 88 Switch Ideas
- 59 Wireless Ideas
- 7.3K Consumer Product
- 329 Service & License
- 537 News and Release
- 106 Security Advisories
- 5.5K FAQ
- 91 About Community
- 124 Security Highlight
