Firmware Upgrade Versions
duggleb
duggleb Posts: 21
image  Freshman Member
I have a NAS326. In System ¦ Firmware Upgrade I see I am currently
V5.21(AAZF.10) ¦ 2019/07/14 22:46:33 ¦ "The firmware version is up-to-date", but in the Zyxel Download Section I see there are several after my version, the latest being V5.21(AAZF.14)C0.
Can I download just this version and install it or should I go through all the intermediate versions first?
  • Mijzelf
    Mijzelf Posts: 3,080
    image  Guru Member
    edited November 2023 Answer ✓
    You don't need to install the intermediate versions. But make sure to read the release notes to see if the upgrade doesn't remove functionality that you are using. When I remember well cups is removed, which is needed to use the NAS as printserver.
  • Mijzelf
    image  Guru Member
