How to modify the AP management-VLAN settings via console when it loses connection with controller
Zyxel_HsinBo
Scenario: When an AP is running in AP Controller (APC) managed mode, and you cannot access the local GUI to modify the management VLAN settings. This is particularly useful if the AP loses connection with the APC due to an incorrect IP configuration
Steps:
- Remote into the AP via console cable.
- Enter Configuration Mode:
Router> configure terminal
3. Modify the management-VLAN:
Router(config)# capwap ap vlan [vlan-id] [tag/untag].
*Replace [vlan-id] and tag/untag with the expect values.
4. Wait until the settings apply, then enter 'write' CLI to keep the modification:
Router(config)# write
Note: This method provides a reliable way to manage VLAN settings remotely, especially in scenarios where direct access to the AP's GUI is not possible.
- 244 Nebula Ideas
- 6.9K Security
- 805 USG FLEX H Series
- 392 Security Ideas
- 88 Switch Ideas
- 60 Wireless Ideas
- 7.3K Consumer Product
- 330 Service & License
- 540 News and Release
- 106 Security Advisories
- 5.5K FAQ
- 89 About Community
- 124 Security Highlight
