How to use CLI to delete multiple IP addresses on a WAN interface settings?
Question :
As the FAQ : How to use CLI to add multiple IP addresses on a WAN interface? mentioned, we can use the CLI to add multiple IP addresses on a WAN interface. But how do we delete this setting? This FAQ will guide you.
Answer :
If I want to delete the three static IPs, 61.222.75.15, 61.222.75.16, and 61.222.75.17, on the USG Flex 200HP GE2 interface, you can use the CLI to execute the following commands:
usgflex200hp> edit running
usgflex200hp running config# del vrf main interface ethernet ge2 ipv4 address 61.222.75.15
usgflex200hp running config# del vrf main interface ethernet ge2 ipv4 address 61.222.75.16
usgflex200hp running config# del vrf main interface ethernet ge2 ipv4 address 61.222.75.17
usgflex200hp running config# commit
Configuration committed.
Once it is done you can use show interface to check the CLI result and you will find those three static IP addresses were gone.
- 241 Nebula Ideas
- 6.8K Security
- 755 USG FLEX H Series
- 380 Security Ideas
- 58 Wireless Ideas
- 7.2K Consumer Product
- 321 Service & License
- 512 News and Release
- 99 Security Advisories
- 5.3K FAQ
- 90 About Community
- 119 Security Highlight
