AP - No devices found and goes offline every 7 or 8 minutes
susymaniero
edited March 2024 in Nebula
Hi, my access point doesn't see any device connected to the wifi network... by the way, there is also another problem: from what I see from "Site-wide > Monitor > Access points > Event log" and "Site-wide > Devices > Access points > Access Point Studio" it seems that the access point goes offline every 7 or 8 minutes! It goes offline, then immediately comes back online 7 or 8 minutes and then it's offline again.
How can I solve these problems?
  • tonygibbs16
    tonygibbs16 image  Guru Member
    50 Answers 500 Comments Friend Collector Fifth Anniversary
    Hello @susymaniero
    Welcome to the forum.
    Are you able please to say what model number of Zyxel access point you have, and what firmware it is on?
    Kind regards,
    Tony
  • Zyxel_Kay
    Zyxel_Kay image  Zyxel Employee
    edited March 2024
    Hi @susymaniero
    There could be several reasons causing your Nebula device to go offline. To help you troubleshoot and resolve the issue, please refer to this comprehensive troubleshooting guide:
    If the problem persists after following the guide, kindly provide us with the following details:
    1. Are your end devices experiencing internet disconnections when connected to a specific access point?
    2. Please enable Zyxel Support on Nebula CC, and provide us your org. and site name, so that we can initiate a more in-depth investigation into the problem.
    Kay
Nebula Tips & Tricks
