How to check if AP no LED light up?
Zyxel_HsinBo
Zyxel_HsinBo Posts: 532
Zyxel Certified Network Engineer Level 2 - Switch Zyxel Certified Network Engineer Level 1 - Switch Zyxel Certified Network Administrator - Security Zyxel Certified Network Administrator - WLAN
image  Zyxel Employee
edited March 2024 in AP & Port setting
If you notice that the LED on your Access Point is not lighting up, there's a straightforward process to diagnose and resolve this issue. Firstly, access the Nebula Control Center by navigating to
Nebula >> Configure >> Access Points >> General Settings
Here, check if the "LED lights" option is enabled. If it's turned off, simply enable it.
If the LED lights option is already enabled but the LED still isn't lighting up, it might indicate a hardware issue with your device. In such a case, you can get further assistance by filling in your device's serial number at the following support link to initiate an RMA (Return Merchandise Authorization) service:
Zyxel Support Request Form.
