How to customize PVID and allow-VLANs for specific AP LAN port?
Zyxel_HsinBo
Zyxel_HsinBo Posts: 532
Zyxel Certified Network Engineer Level 2 - Switch Zyxel Certified Network Engineer Level 1 - Switch Zyxel Certified Network Administrator - Security Zyxel Certified Network Administrator - WLAN
image  Zyxel Employee
edited May 2024 in AP & Port setting
Following the below steps, you can customize the PVID and allow VLAN for specific Nebula-managed APs according to your requirements.
  1. Navigate to Nebula >> Configure >> Access points >> AP & port settings
  2. Scroll down the page to the AP list part, and single tap on the AP which you want to configure the specific PVID/Allow VLAN.
  3. Click the OK and Save button to keep the modification.
