NWA130BE Lan Port for VLAN 2
George993
George993 Posts: 21
First Comment First Answer Friend Collector Second Anniversary
image  Freshman Member
edited July 2024 in Nebula
How can I change the LAN port of the NWA130BE to flow all traffic through it to VLAN2?
Thanks,
George
Best Answers
  • davidfi01
    davidfi01 Posts: 26
    First Comment First Answer First Anniversary
    Change PVID to "2" in your case - that should work.
  • Zyxel_Judy
    Zyxel_Judy Posts: 2,762
    image  Zyxel Employee
    Hi @George993 ,
    If your access point supports a LAN port, it will be listed at the bottom of the page.
    To change the LAN port settings of a specific AP, click on that AP and configure the settings.
    Zyxel_Judy
  • davidfi01
    davidfi01 Posts: 26
  • George993
    George993 Posts: 21
    Thanks David. I use Nebula and found it as well in the AP and Port settings. Good to know where I can change it as well if I decide not to renew Nebula. I assume you have to change it for every AP when web managed? I wish there was a way in Nebula to apply it only to one AP, it changes all of them.
    George
  • Zyxel_Judy
    Hi @George993 ,
    Zyxel_Judy
Nebula Tips & Tricks
