LTE7490 in Routing mode (multi-WAN setup)
Zio
Zio Posts: 1 image  Freshman Member
edited October 2024 in Mobile Broadband
I own an LTE7490-M904 LTE router and I am having troubles setting it up in Routing mode (IP passthrough is not an option).
The target setup is as follows:
  • LTE7490 acting as a router on fixed IP internal interface (i.e., 192.168.2.1)
  • Multi-WAN router port configured with fixed IP (i.e., 192.168.2.2) using the LTE7490 as default gateway (and DNS proxy) on 192.168.2.1
  • Access to the LTE7490 web configuration interface through LAN on 192.168.2.1
  • LTE7490 acting as WiFi AP, for internet and access and LTE7490 web configuration interface
Something like this:
I have tried many configurations so far, but even with the simplest setup the LTE7490, when in Router mode, cannot be pinged (and no internet access is available on either interface, LAN or WiFi).
Is this configuration supported? If yes, how shall the LTE7490 be configured?
Thanks!
  • Bob_C
    Bob_C Posts: 224
    image  Master Member
    Hi Zio,
    1. The LTE7490's Wi-Fi is only for local management. It does not support accessing the Internet.
    2. For the LTE7490's LAN, if the end device gets an IP address from the LTE7490 instead of setting a static IP address, can the end device receive ping response from the LTE7490?
    3. What is the LTE7490's firmware?
    Regards,
    Bob
