Why does Nebula CC display "Base Pack" when I have a Pro Pack license?
Zyxel_Kay
Zyxel_Kay image  Zyxel Employee
Background
Nebula Control Center (Nebula CC) provides license-based features categorized into Base, Plus, and Pro Packs. Licenses enable advanced functionalities for organizations using Nebula.
Issue & Root Cause
Your organization may display as using the "Base Pack" despite holding a Pro Pack license. This happens because Nebula licenses apply organization-wide, and all devices within the organization must have the same license level (e.g., Pro) for the Nebula CC to reflect that status.
Resolution
  1. Verify license status under Organization-wide > License & Inventory in NCC.
  2. Assign or purchase Pro Pack licenses for unlicensed devices.
For detailed guidance, visit https://www.zyxel.com/global/en/nebula-license-overview .
More Information
Kay
