How to Resolve Connection Speed Issues with Zyxel Access Points?
Zyxel_Jami
in Other Topics
If your Zyxel access point (AP) shows reduced connection speed, follow these steps:
- Ensure that the Ethernet cable is Cat5e or higher.
- Switch the AP to a different Ethernet port on the switch.
- Reset the AP to its factory settings. Refer to this link for detailed reset steps.
- If the problem persists, swap the problematic AP with another AP that you know works well using the same cable and switch port. If the known good AP maintains a good connection, this indicates a hardware issue with the original AP.
- 244 Nebula Ideas
- 6.9K Security
- 804 USG FLEX H Series
- 392 Security Ideas
- 88 Switch Ideas
- 60 Wireless Ideas
- 7.3K Consumer Product
- 330 Service & License
- 540 News and Release
- 106 Security Advisories
- 5.5K FAQ
- 91 About Community
- 124 Security Highlight
