How to Upgrade Firmware on the WAX610D Access Point Using TFTP?
Zyxel_Jami
Upgrading the firmware on your WAX610D Access Point using TFTP can be done by following these steps:
- Ensure that the AP's uplink port is connected to the switch or gateway.
- Verify that both the AP and the TFTP server are connected to the same subnet.
- Set the current directory on your computer to the default TFTP path:
C: Program Files Tftpd64. - Place the firmware file you wish to update in this directory.
- Temporarily disable the Windows firewall settings, including the Private network profile. You can follow the detailed instructions available at this Microsoft Support link.
Please refer following link for further guidance:
Firmware recovery steps for Zyxel Access Points
- 244 Nebula Ideas
- 6.9K Security
- 797 USG FLEX H Series
- 391 Security Ideas
- 88 Switch Ideas
- 59 Wireless Ideas
- 7.3K Consumer Product
- 327 Service & License
- 531 News and Release
- 104 Security Advisories
- 5.4K FAQ
- 91 About Community
- 124 Security Highlight
