XGS1930-52 Troubleshooting 10GbE connection issue
Hello.
I purchased 2 DAC10G-3M-ZZ0103F cables, I tested them in my lab with 2 PCs with Intel X520-DA1 10Gb network cards connected directly without a switch and I measured the speed with the iperf3 software obtaining 9.8Gbit.
After that I installed them at the customer's on two servers with the same network cards and the same DAC10G-3M-ZZ0103F cables but connected via the XGS1930-52 switch, the 2 links activate correctly at 10Gbit but the maximum speed I reach with the iperf3 software between the two servers is 1.3Gbit. Could it be that the switch limits the speed so much?
Hi @aimirco,
What is the test result if you connect two issue servers directly? Please help check this issue so we can better clarify it.
Zyxel Melen0 -
I was not able to test connecting the two servers without the switch at my customer's site, however I noticed that one of the two servers pinging the XGS1930-52 switch often loses packets, perhaps it is a faulty DAC10G-3M cable.
I replaced the DAC10G-3M cable and now it no longer drops packets but the maximum speed has not changed.
Hi @aimirco,
Kindly remind: XGS1930 series needs to change the media type if you use DAC cable.
Why my switches cannot connect with a DAC cable? — Zyxel Community
Zyxel Melen0
- 241 Nebula Ideas
- 6.8K Security
- 761 USG FLEX H Series
- 383 Security Ideas
- 58 Wireless Ideas
- 7.2K Consumer Product
- 323 Service & License
- 522 News and Release
- 100 Security Advisories
- 5.3K FAQ
- 90 About Community
- 119 Security Highlight
