Wireless SSID not visable
Yesterday i had an strange thing. i have 3 wifi networks. but i just can find 1 (on both laptop as phone). all networks are enabled, and offcourse not hidden SSID. I didn't have time to investigate it yet, but i see this in the logging:
2 ports control blocks? what does this mean?
Can it has something to do with it?
I will investigate it later further.
Hi @Dpj,
Thanks for sharing the log.
The message
ZDP: initial port [number] control blockindicates that the Zyxel Device Protocol is initializing the control process for a network port. You may refer to this FAQ for more details on what this log means.As for your issue with only 1 SSID being visible (while all 3 should be), we also recommend checking this FAQ as well to help troubleshoot and resolve the problem.
Zyxel Tina
Hi @Dpj,
The message
Zyxel Tina
Thank you Tina, Yes i think it had to to with the time schedules. Not completely sure, but now they are sending
- 235 Nebula Ideas
- 6.7K Security
- 734 USG FLEX H Series
- 375 Security Ideas
- 58 Wireless Ideas
- 7.1K Consumer Product
- 319 Service & License
- 511 News and Release
- 99 Security Advisories
- 5.2K FAQ
- 90 About Community
- 117 Security Highlight
