Nebula Site-to-Site SD-VPN between USG Flex and USG Flex H doesent work
I have an issue with the Nebula VPN between a USG Flex H and a USG Flex.
No connection is being established via the Nebula SD-VPN. Connections using a Manual-link VPN are working.
These errors are in the Log.
IPSec VPN SA_7049 C9_11 is down, try to nail up
IPSec VPN SA_FC22F 9FC_11 is down, try to nail up
IPSec VPN SA_FC2 78C_11 is down, try to nail up
IPSec VPN SA_FC2 1E1_11 is down, try to nail up
IPSec VPN SA_F44 4EC1_11 is down, try to nail up
IPSec VPN SA_F44D5 2A_11 is down, try to nail up
IPSec VPN SA_FC2 72_11 is down, try to nail up
All my USG Flex without H are Working with Nebula SD-VPN.
Can anyone help?
Hi @KMZ
This is because the H side VPN DDNS didn't update. This is a bug on firmware. I will provide you the fix via private message.
Zyxel Melen0
Hi @KMZ
Could you help to enable Zyxel support access and share your organization's name so we can access to check?
Zyxel Melen0 -
I enabled the support access.
Organization's Name: Landkreis Nordwestmecklenburg
Site: KAM Buero
Thank you.
Hi @KMZ
Zyxel Melen0
- 244 Nebula Ideas
- 6.9K Security
- 800 USG FLEX H Series
- 392 Security Ideas
- 88 Switch Ideas
- 59 Wireless Ideas
- 7.3K Consumer Product
- 328 Service & License
- 532 News and Release
- 104 Security Advisories
- 5.5K FAQ
- 91 About Community
- 124 Security Highlight
