Locked Zyxel NR7103 (O2 Slovakia) - Web GUI inaccessible, need generic firmware
Hello Zyxel Community support,
I have a Zyxel NR7103 outdoor 5G antenna that was originally distributed by a local internet provider, O2 Slovakia.
I am currently facing a major issue: the Web GUI is completely inaccessible. Even when my PC is connected directly via LAN cable to the PoE injector (with cellular data/Wi-Fi disabled) and I try to access the default gateways (such as 192.168.9.1 used by O2, or standard 192.168.1.1 via HTTP/HTTPS), the browser always returns a timeout or connection refused error. The antenna broadcasts its internal Wi-Fi network and assigns IP addresses, but the management page seems to be completely disabled or locked out by the provider's custom firmware. Hard reset via the physical button did not solve the problem.
Because of this, I am unable to check my current firmware version from the web interface. However, I need to completely remove the provider's branding, un-lock the device, and flash the official clean generic firmware so I can gain full admin access and use it properly.
Could you please provide me with a download link for the latest generic firmware (and the matching LTE/5G module upgrade package) for the NR7103? I will flash it locally once I manage to force a connection or recovery.
Thank you very much for your help!
SN: S230Z28016023
Hello!
About ip on your NR7103…
If you use advanced IP scanner i think you will find the right IP for your unit….
Download, install and hit green arrow scan.🙂
BTW I own a LTE7490 and a NR7101 which i use in my other houses, not here as you see….😊
https://www.advanced-ip-scanner.com/
//J.
- 244 Nebula Ideas
- 6.9K Security
- 805 USG FLEX H Series
- 392 Security Ideas
- 88 Switch Ideas
- 60 Wireless Ideas
- 7.3K Consumer Product
- 332 Service & License
- 540 News and Release
- 106 Security Advisories
- 5.5K FAQ
- 89 About Community
- 124 Security Highlight
