What Is an IoT SSID and How to Enable It?
Zyxel_JoyLee
Zyxel_JoyLee Posts: 244
Friend Collector First Anniversary
image  Zyxel Employee
edited October 29 in SSID
What is IoT SSID?
•A one-click optimization that automatically adjusts existing SSID settings for better IoT device compatibility
•Users can quickly apply IoT-friendly settings without manually configuring each option on NCC
How to enable it?
  1. Site-wide > Configure > Access point > SSID settings > simple mode(Advanced mode is disabled)
•Click Optimize settings to apply IoT-friendly settings to each SSID
2. Site-wide > Configure > Access point > SSID settings > Advanced mode(Advanced mode is enabled) and then go to Site-wide > Configure > Access point > SSID advanced settings
•A confirmation message appears before applying the changes
•Change Log
  • A change log is generated to record:
• IoT compatibility is applied
•The configuration changes made to the SSID
