NSA325 Firmware upgade problem
djep
After I did a firmware upgrade to the latest version: 4.81, my Zyxel not working anymore.
The first led continuously flashing in green, and I can't access the share, or web interface.
I tried with reset button, turn off power and on again, but nothing happens. It's not first firmware upgrade, but with this I have trouble. What can I do?
It is a manual procedure to install the firmware from USB stick? Can anybody help me with instructions. Thank you in advance.
#NAS_October
#NAS_October
Hi @djep
I think you can find information here :
http://zyxel.nas-central.org/wiki/Restoring_Firmware
(adapt the path when necessary)0
Hi @djep
(adapt the path when necessary)0 -
Thank you very muc@Fredzoul1, I succeeded with above method, after three attempts. Front USB port (USB 3) didn't work. But the rear USB port worked like a charm. Thank you again.
Perfect :-) I'm Happy0
I've got the same problem, during an upgrade, it got stuck with flashing orange light and no more........
When I try to follow the link it fails.
Through this article, it seems the server is not ready yet, because the data center was just moved.
https://homeforum.zyxel.com/discussion/comment/2881#Comment_2881/
- 244 Nebula Ideas
- 6.9K Security
- 808 USG FLEX H Series
- 392 Security Ideas
- 88 Switch Ideas
- 60 Wireless Ideas
- 7.3K Consumer Product
- 333 Service & License
- 541 News and Release
- 106 Security Advisories
- 5.5K FAQ
- 89 About Community
- 124 Security Highlight
