What does Red Solid LED mean?
Zyxel_Support
During
installation, if you observe the Red Solid LED, it means the Bluetooth doesn’t
work well. Please reboot the Multy unit and try it again.
After installation
is complete, Red Solid LED represents Internet disconnection for the 1st node.
Please check your Internet connection first.
After installation is complete, Red Solid LED on the 2nd node represents backhaul disconnection. Please make sure the 2nd node is not moved far from the 1st node. If it still shows Red Solid LED, please try to remove the 2nd node from the WiFi system and add it back again by using Multy app.
- 244 Nebula Ideas
- 6.9K Security
- 800 USG FLEX H Series
- 392 Security Ideas
- 88 Switch Ideas
- 59 Wireless Ideas
- 7.3K Consumer Product
- 328 Service & License
- 532 News and Release
- 104 Security Advisories
- 5.5K FAQ
- 91 About Community
- 124 Security Highlight
