Extremely slow network speed NAS326
MikkelDK
I just got a NAS326 - but Im very
with the network wpeeds from this unit.
My dsl router is Zyxel VMG8924-B10A, and i have connected the NAS326 to this router.
My preferred setup is wireless, but if i connect my pc wireless to the router, and test with a 200 mb file, i get write speeds around 1-3 MB/sec, and read speeds around 1-3 MB/sec. I thought that this unit was capable of speeds around 100 MB/sec.
If i copy this 200 mb file, i can see that the transfer "pauses". The green progression bar moves quickly, and then i stops for seconds, and then move again, ant then stops. Is that the cache beeing filled up
If i cable my pc to the router, it gets a little better, but the best performance i get, is that if i only uses the zyxel router as a modem, and the connect a cisco router to the zyxel, and then connect the NAS326 and my pc via cable to the cisco. Then the NAS performance tester says that i have 3 MB7sec write, but 100 MB/sec read. This is what the performance tester says, but if i windows copy a large 1 gb file from the NAS to local pc, i can see that the green bar again moves with big pauses. I goes very fast for like 2 seconds, then a pause for 10 seconds, then vary fast for 2 seconds, and then pause and som on. Im not very satisfied with that NAS, it really seems like there is som serious performance issues. Firmware is updated.
How van i get this NAS to perform so i can use it ? I mean if it takes me 45 minutes to transfer a 1 gb file, i will throw it out. Useless.
#NAS_March
#NAS_March
What is your platform?
I can see my speed of upload and download can upto 80~100Mbps, but sometimes if HDD or PC is busy, then the speed will be dropdown to 60~80Mbps.
Here is my test in old post:
https://homeforum.zyxel.com/discussion/comment/737#Comment_737
- 244 Nebula Ideas
- 6.9K Security
- 802 USG FLEX H Series
- 392 Security Ideas
- 88 Switch Ideas
- 59 Wireless Ideas
- 7.3K Consumer Product
- 329 Service & License
- 532 News and Release
- 104 Security Advisories
- 5.5K FAQ
- 91 About Community
- 124 Security Highlight
