Help on how to hide SSID on Multy X system.
Chanter
Chanter image  Freshman Member
edited May 2018 in Multy WiFi System
Just installed a Multy  system. Can't find settings to hide SSID. Can anyone help? Thanks
#MultyX_May
  • Zyxel_Steven
    Zyxel_Steven image  Zyxel Employee
    edited May 2018
    Multy X doesn't support to hide SSID. May we know what is your purpose?
    Multy X is supported to disable/enable WiFi on WiFi Settings.
  • Chanter
    Security!  I have used ASUS, Netgear, etc wifi systems and all have ability to hide SSID. This is basic security to help prevent sniffing. If someone doesn't know the SSID exists, they can't try to get in. I am VERY surprised that such a sophisticated company as Zyxel doesn't include this and even more surprised that Zyxel would ask why I'd want it. Tony
  • Chanter
    Totally agree about a good key. But why not good key AND obscurity as from other suppliers? Can this be put on a development list?
  • Zyxel_Steven
    Thanks for your feature request in Multy X, we will evaluate it.
