Should I use the same SSID for 2.4GHz and 5GHz in Multy Plus (WSQ60)?
Zyxel_Support
It is recommanded to use the same SSID for 2.4G and 5G becasue of the band steering feature. Multy Plus has to
be set up with the same SSID for 2.4GHz band and 5GHz band for guiding your
connected devices to connect to the band with the best performance.
Although Multy Plus allows users to set different WiFi SSIDs for 2.4GHz and 5GHz, there will be two separated WiFi networks (one for the 2.4GHz band and the other for the 5GHz band) and users have to connect to different bands manually and the band steering feature will be disabled.
- 242 Nebula Ideas
- 6.8K Security
- 779 USG FLEX H Series
- 387 Security Ideas
- 58 Wireless Ideas
- 7.2K Consumer Product
- 324 Service & License
- 526 News and Release
- 101 Security Advisories
- 5.3K FAQ
- 91 About Community
- 121 Security Highlight
