Should I use the same SSID for 2.4GHz and 5GHz in Multy U (WSR30)?
Zyxel_Support
It is recommanded to use the same SSID for 2.4GHz and 5GHz becasue of the band steering feature. Multy U (WSR30) has to be set up with the same SSID for 2.4GHz band and 5GHz band for guiding your connected devices to connect to the band with the best performance.
Although Multy U (WSR30) allows users to set different WiFi SSIDs for 2.4GHz and 5GHz, there will be two separated WiFi networks (one for the 2.4GHz band and the other for the 5GHz band). Users have to connect to different bands manually with different SSIDs and the band steering feature will be disabled.
- 237 Nebula Ideas
- 6.8K Security
- 745 USG FLEX H Series
- 377 Security Ideas
- 58 Wireless Ideas
- 7.2K Consumer Product
- 319 Service & License
- 512 News and Release
- 99 Security Advisories
- 5.3K FAQ
- 91 About Community
- 119 Security Highlight
