can i connect 2 multy x hubs together using ethernet
gz00
gz00 Posts: 1 image  Freshman Member
edited November 2018 in Multy WiFi System
I have an old house some parts dating from 1600s with metre thick stone walls. Wi-fi won't penetrate. Can I connect using ethernet?
#MultyX_Nov_2018
  • Dash
    Dash Posts: 65 image  Ally Member
    Multy X seems still not ready to implement Ethernet backhaul.
    I try to connect two Multy X nodes via Ethernet cable directly. It works, but not sure there is any issue about that. First, you need to setup Multy X to use wireless backhaul, then use Ethernet cable to connect two nodes directly.
    Internet---<WAN Port>1st node<LAN Port>---<Any Port>2nd node
