How can I adjust the signal strenght at multi plus
Rotsch
my multi plus are place at ground floor and the 1st floor (distance 6m). The signal strenth are around -64db (to close).
#MultyPlus_Feb_2019
#MultyPlus_Feb_2019
If 2nd node is too close 1st node, you need to move 2nd node to another place. Because there is no way to adjust the signal strength.
Have you encountered any problems with the use?
- 241 Nebula Ideas
- 6.8K Security
- 760 USG FLEX H Series
- 381 Security Ideas
- 58 Wireless Ideas
- 7.2K Consumer Product
- 323 Service & License
- 521 News and Release
- 100 Security Advisories
- 5.3K FAQ
- 90 About Community
- 119 Security Highlight
