Second node not turning to blue led for setup
Alexhdz321
Hello team I recently purchased the Multy U system and I am having issues with the secondary node. It is staying in a solid white LED and will not change to blue. I attempted to reset using the button on the back multiple times with no changes. Any suggestions on how to resolve this issue?
#MultyU_May_2019
#MultyU_May_2019
When you press the reset button for at least 5 seconds, do the LED starts to blink amber or anything happen on LED? Does the LED always solid white? Do you not able to add 2nd node?
Hi Alexhdz321,
Has the secondary node been install before? As you said: it is staying in a solid white LED, how long you're waiting for LED status? Always is solid white and not change to blue?
You can try to hold reset button of Multy U, and then power on Multy U, when the LED turns to green, please release reset button. After that, please power off and power on Multy U to check its LED can turn to blue and ready for installation.0 -
Hello team, I ended up replacing the node after trying the steps above.1
- 238 Nebula Ideas
- 6.8K Security
- 754 USG FLEX H Series
- 377 Security Ideas
- 58 Wireless Ideas
- 7.2K Consumer Product
- 320 Service & License
- 512 News and Release
- 99 Security Advisories
- 5.3K FAQ
- 90 About Community
- 119 Security Highlight
