NAS542 extremely slow write speed, CPU 100 %
2»
  • TomasMalina
    TomasMalina Posts: 35 image  Freshman Member
    First Answer First Comment Friend Collector Fourth Anniversary
    Do you think this masked bug could be what's causing the higher load average, or those would be just network pings/calls (indicated by the spikes in PID number)? Would a firmware reinstall (from here I guess? ftp://ftp.zyxel.com/NAS542/firmware) help?
  • Mijzelf
    Mijzelf Posts: 3,070 image  Guru Member
    Unlikely. It's hard to presume a link between leaking a semaphore and starting an excessive number of processes. Further my NAS520 doesn't have that problem, and that also has that script.
    Maybe. But then I would expect a blinking led. I'm not sure if a ping will burn a pid. It's handled by the kernel, and I don't know if it will start a (kernel) process for that.
    Would a firmware reinstall help?
    I doubt. But it won't hurt.
  • TomasMalina
    Okay, thank you for your help and time.
