Low Backhaul on AC3000 Multy
AMDB9
AMDB9 Posts: 1 image  Freshman Member
edited January 2020 in Multy WiFi System
The backhaul between my two AC3000's is only 288mbps transfer rate. I thought I would get something over 1000.  The Multy App says the locations are optimal. Is there any chance I have messed the settings?
#MultyX_Jan_2020
  • Zyxel_Eric
    Zyxel_Eric Posts: 279
    First Answer First Comment
    image  Zyxel Employee
    edited January 2020
    Dear Sir,
    1.The location detection is according to the signal from each Multy, but the throughput between two nodes will be affected by the environment, and that affection may cause by the wall, ceiling, signal interference, distance, etc.
    2. Is it possible to share the Diagnose result of your Multy App?
    3. May I know the throughput from the internet to the second node?
