NAS540 "volume is down" after firmware upgrade
elbosoti
elbosoti Posts: 1 image  Freshman Member
edited January 2020 in Personal Cloud Storage
I recently decided to upgrade my firmware for the nas540, it was on version 5.04 AATB0, which didn't work at first. I managed to manually update it to 504AATB0_20150813.bin and then I was able to update it to the latest version (v5.21). but after updating it I couldn't log into it anymore so reset the password and ip. But now it's showing up as "volume is down" on the web interface and on the nas seeker it says it needs to be initialized.
I managed to get into the telnet connection and get this from the cat command:
~ # cat /proc/mdstat
Personalities : [linear] [raid0] [raid1] [raid10] [raid6] [raid5] [raid4]
md2 : active raid5 sdb3[0] sde3[3] sdd3[2] sdc3[1]
      17569172928 blocks super 1.2 level 5, 64k chunk, algorithm 2 [4/4] [UUUU]
md1 : active raid1 sdb2[0] sde2[3] sdd2[2] sdc2[1]
      1998784 blocks super 1.2 [4/4] [UUUU]
md0 : active raid1 sdb1[0] sde1[3] sdd1[2] sdc1[1]
      1997760 blocks super 1.2 [4/4] [UUUU]
unused devices: <none>
I am not at all familiar with RAID5 and would like to get it back up and running
#NAS_Jan_2020
  • Mijzelf
    Mijzelf Posts: 3,074 image  Guru Member
    Here is your problem: 17569172928 blocks
    On firmware 5.0x volumes up to 256TiB were supported, on 5.10 and up only 16TiB.  I wrote about the technical background here.
    So you'll have to downgrade to get your volume back.
    When 5.10 was launched, ZyXEL had some tool/workaround to shrink the volume first to <16TiB before upgrading. But I don't know how they managed to change the block size of the ext4 filesystem.
  • Mijzelf
