web interface for multy x ac3000
Gerrit
Gerrit Posts: 1 image  Freshman Member
edited June 2020 in Multy WiFi System
is there a way to configure the Multy X AC3000 by web interface?
the huge advantage is that you can configure the Multy X AC3000 for ever and not depending on the app
#Multy_May_2020
  • Zyxel_Eric
    Zyxel_Eric Posts: 279
    First Answer First Comment
    image  Zyxel Employee
    Dear Sir,
    Multy X only supports App management.
    If you prefer to manage Multy via the Web interface, Multy Plus will be what you need.
    Multy Plus supports Web GUI.
    Please refer to the link for Multy Plus:
    https://www.zyxel.com/products_services/AC3000-Tri-Band-WiFi-System-Multy-Plus/
    Best Regards,
    Eric
  • yury_de
    yury_de Posts: 2
    First Anniversary
    Dear support,
    can you explain the logic of having only "app management" please?
    User case: if something configured wrong, that you've got no WIFI and the only way you have to reset completely the device.
    My Zyxel Multy U becomes a brick if I activate "Bridge mode", and that's quite easy to do, for there's no confirmation for this action.
    Thank you.
    Best regards,
    Yury
  • Zyxel_Can
    Zyxel_Can Posts: 342
    25 Answers First Comment Friend Collector
    Hi @yury_de,
    Thank you for your feedback.
    We will consider this forum entry as feature evaluation.
    Regarding to your "Bridge Mode" problem, please send feedback using your smartphone's Multy app.
