About LTE3316-m604 4g/lte speed
FADATSAI
My LTE3316-m604 has POOR 4g/LTE speed compared to TP-link TL-MR6400, whitch doesn't even support CA,. I use the same sim card(T-star, Taiwan) at the same location. Do I need external antenna to get better signal? Or do you have any upgrade at firmware?
Your website says it support "Zyxel LTE Ally", but i didn't see anything about LTE3316-M604 in the app.
By the way I'm using iOS.
If I have to buy external antenna, what kind of antenna should I buy?0
Good, now I can't even connect to my chromecast which works fine on my previous AP( or even on my phone-shared wifi). And I found same issue on this forum but no one seemed to have it solved.0
Firmware version:V1.00(ABQS.0)C00
Hi FADATSAI , Zyxel LTE Ally is under development, it notice on the bottom of Zyxel LTE3316-M604 specification web page.(https://www.zyxel.com/tw/zh/products_services/4G-LTE-A-Indoor-IAD-LTE3316-M604/specifications)When you buy the external antenna, you should check if the external antenna support the frequency bands same as LTE3316-M604, and buy the external LTE/3G antenna SMA male because LTE3316-M604 has two external LTE/3G antenna SMA female connector.0
- 243 Nebula Ideas
- 6.9K Security
- 793 USG FLEX H Series
- 391 Security Ideas
- 88 Switch Ideas
- 59 Wireless Ideas
- 7.3K Consumer Product
- 327 Service & License
- 530 News and Release
- 104 Security Advisories
- 5.4K FAQ
- 91 About Community
- 122 Security Highlight
