What's the max. speed between Multy X and Multy mini?
Luigi Chang
What is the maximum transmission speed between the Multy X and the Multy Mini if the Internet is set to turn off the "Daisy Chain"?
#Multy_Jun_2020
#Multy_Jun_2020
Dear Sir,
Base on the spec, Multy mini has 1300Mbps wireless transfer rate on 5G.
The wireless backhaul connection is on 5G wifi.
So the max transfer speed for Multy Mini to Multy X is 1500Mbps
Please Note, this rate is a theoretical value.
The actual data transfer rates may vary from network conditions including: distance, network traffics, building site material/construction, interference from other wireless devices and other adverse factors.
Regarding the Daisy Chain,
Daisy Chain setting will not affect the speed rate between Multy.
Best Regards,
Eric0 -
Still has few questions.
XDSL <=======> Multy X <======> Multy mini
by cable by cable
Above is my Multy’s connection.1. My XDSL is 500Mbps/300Mbps.2. XDSL, Multy X and Multy mini are connected by cable.
3. Multy X: DL 485Mbps, UL: 325Mbps from the internet
4. Multy X to Multy mini is 850Mbps and 875Mbps3 and 4 are tested by Multy App.
My question is why is the speed from Internet to my Multy Mini only DL 130Mbps and UL 90Mbps?
Thanks.0 -
Dear Sir,
1. Is the 130/90 the result from the Diagnose page of Multy App?
Or the result that you test from your PC which connects to the Multy Mini via Wifi?
2. Can you provide the Diagnose result page from App?
Best regards,
Eric
Hi Eric,
This result is from App. (By diagnose)
If you can provide me with your mail address. I can send you the screenshot for reference.
Thanks.
Luigi0 -
Dear Sir,
I have contacted you via private message, please check your message box for further assistance.
Best Regards,
Eric0 -
Hi Eric, Can you share the result of your finding or resolution on the forum? I have a similar query.0
- 237 Nebula Ideas
- 6.8K Security
- 740 USG FLEX H Series
- 376 Security Ideas
- 58 Wireless Ideas
- 7.2K Consumer Product
- 319 Service & License
- 512 News and Release
- 99 Security Advisories
- 5.3K FAQ
- 91 About Community
- 119 Security Highlight
