NAS326 problem - part 2 - help is needed - Volume is down
Janikovo
Hello all,
and especially @Mijzelf
You probably know my problem with one faulty disk on NAS326 (linear, jbod).
Look here: https://homeforum.zyxel.com/discussion/3827/nas326-problem/p1
Problem is how to "assemble" NAS volume (or array back) without losing data.
So, I managed with ddrescue copied 99.999% of that faulty disk to the news HDD same size.
Installed the new disk to NAS, but the situation is as follows:
What should I do now ?
Please an advice
and Thanks.
#NAS_June_2020
Please an advice
and Thanks.
#NAS_June_2020
The array is assembled, but it fails to mount. So try running fsck:e2fsck /dev/md20
OK,
i tried add -n to e2fsck
and it show this:~ # e2fsck -n /dev/md2e2fsck 1.42.12 (29-Aug-2014)Warning! /dev/md2 is in use.ext2fs_open2: Bad magic number in super-blocke2fsck: Superblock invalid, trying backup blocks...e2fsck: Bad magic number in super-block while trying to open /dev/md2The superblock could not be read or does not describe a valid ext2/ext3/ext4filesystem. If the device is valid and it really contains an ext2/ext3/ext4filesystem (and not swap or ufs or something else), then the superblockis corrupt, and you might try running e2fsck with an alternate superblock:e2fsck -b 8193 <device>ore2fsck -b 32768 <device>
btw:
mdadm --stop /dev/md2:~ # mdadm --stop /dev/md2mdadm: Cannot get exclusive access to /dev/md2:Perhaps a running process, mounted filesystem or active volume group?So, I cant stop md2
How could I assemble volume (array) without losing data ?0 -
So, I cant stop md2
You can't stop md2, because it's busy. md2 is not mounted, so there must be something else. I should have looked further, apart from md2 there is also a dm-1 in /proc/partitions, which is slightly smaller than md2. So inside your raid array there is a 'logical volume', and that logical volume is the one containing the file system.
So try
e2fsck /dev/dm-1
I am not sure if that dm-1 devicenode is inside /dev/. If /dev/dm-1 cannot be found, try
find /dev/ grep dm
to find the path to the devicenode.
- 241 Nebula Ideas
- 6.8K Security
- 758 USG FLEX H Series
- 380 Security Ideas
- 58 Wireless Ideas
- 7.2K Consumer Product
- 321 Service & License
- 520 News and Release
- 100 Security Advisories
- 5.3K FAQ
- 90 About Community
- 119 Security Highlight
