BlueIris LAN connection
uwvid
Hi.
Bare with me, networking isn't my strong side, so I might have missed something obvious.
I'm trying out the Blue Iris (cam nvr) software, and I'm setting up web server. I've port forwarded and can remote access from outside just fine.
LAN is a different story. I can access from host computer, but no other devices on the LAN network.
The problem is I'm using Multy X in Ethernet Backhaul. I set up DMZ, but with no luck. I tried putting the Multy X is bridge mode, but didn't have any luck either.
Any suggestions?
#Multy_Aug_2020
Any suggestions?
#Multy_Aug_2020
Ok, solved it. In Blue Iris software the LAN IP address was pointed to the wrong device for some reason. Pointed it to my Blue Iris device and it worked.0
- 243 Nebula Ideas
- 6.8K Security
- 781 USG FLEX H Series
- 387 Security Ideas
- 58 Wireless Ideas
- 7.2K Consumer Product
- 324 Service & License
- 527 News and Release
- 101 Security Advisories
- 5.3K FAQ
- 91 About Community
- 121 Security Highlight
