NSA 210 Initialisation Problem Invalid Firmware Message
Malcolm_Sharon21
My NSA210 had a red hard disc symbol indicating that the disc was faulty. My PC is windows 10 OS
I have tried to install an new 1 TB drive and then get the NAS to run. I have formatted it with one partition NFTS
I already had the NAS Starter utility loaded and can explore and find the NAS when I move on to run the initialisation wizard I get into a problem I use the standard DHCP DNS option and move on it sets the network. I move on to step 2 which is to locate the firmware to install. I have this saved in a known place (410AFDOCO.bin) click the initialise hard disc option. I get the warning that this will erase all of the previous on the dive and proceed and get to about 30% of transfer firmware when I get an Invalid Firmware box and the process stops. Can't get screenshots of this to work.
Really would appreciate some help with this
Thank you
Did you upgrade the firmware since you originally installed it? If yes, try the latest version.
- 237 Nebula Ideas
- 6.8K Security
- 740 USG FLEX H Series
- 376 Security Ideas
- 58 Wireless Ideas
- 7.2K Consumer Product
- 319 Service & License
- 512 News and Release
- 99 Security Advisories
- 5.3K FAQ
- 91 About Community
- 119 Security Highlight
