nas 326 - resize of volume seems not to work
pingpong
pingpong Posts: 4
Sixth Anniversary
image  Freshman Member
I try to resitze a exisitng volume after I have replaced a older smaler disk group with newer bigger disks. The screen "Volume on disk group" does not show any extention for the volume I have extended. Even though the dialog does not show an error. But the size of the volume is kept unchanged.Same problem like https://homeforum.zyxel.com/discussion/comment/5867
But I was not able to solve it.
  • pingpong
    pingpong Posts: 4
    Sixth Anniversary
    I found a solution myself. The solution is described here
    You may follow the sequence. But you need to find "your" volume which needs to be expanded.
    Here is what I did:
    logon via putty as "root"
    run "lvdisplay "
    ~ # lvdisplay
      --- Logical volume ---
      LV Path                /dev/vg_a246bbf1/vg_info_area
      LV Name                vg_info_area
      VG Name                vg_a246bbf1
      LV UUID                cT3bM4-rmoP-vcla-j4A4-BxQc-9z0o-407q0g
      LV Write Access        read/write
      LV Creation host, time NAS326, 2017-09-04 21:38:34 +0200
      LV Status              available
      # open                 1
      LV Size                100.00 MiB
      Current LE             25
      Segments               1
      Allocation             inherit
      Read ahead sectors     auto
      - currently set to     1024
      Block device           253:0
      LV Path                /dev/vg_a246bbf1/lv_d648b119
      LV Name                lv_d648b119
      VG Name                vg_a246bbf1
      LV UUID                wLV5f3-NFTp-bF1B-0fdk-JVyQ-x3b4-iHWuUM
      LV Creation host, time NAS326, 2017-09-04 21:38:35 +0200
      LV Status              available
      # open                 1
      LV Size                1.96 TiB
      Current LE             513536
      Segments               3
      Allocation             inherit
      Block device           253:1
      LV Path                /dev/vg_a246bbf1/lv_a4b19a90
      LV Name                lv_a4b19a90
      VG Name                vg_a246bbf1
      LV UUID                TS9AMf-SGVk-8X6r-etAd-tj9X-zVSG-zZR3ja
      LV Creation host, time NAS326, 2018-12-27 10:39:29 +0100
      LV Status              available
      # open                 1
      LV Size                1.68 TiB
      Current LE             440316
      Segments               1
      Allocation             inherit
      Block device           253:2
      LV Path                /dev/vg_a246bbf1/lv_067dd4d6
      LV Name                lv_067dd4d6
      VG Name                vg_a246bbf1
      LV UUID                x9slNI-59Kh-OJPC-ubGs-aAhC-t9jy-qZB79q
      LV Creation host, time NAS326, 2019-10-06 16:57:18 +0200
      LV Status              available
      # open                 1
      LV Size                1.96 TiB
      Current LE             512512
      Segments               1
      Allocation             inherit
      Block device           253:3
      Now I got all Logical volume which might be in scope.
    Now follow the sequence:
    1. ran "vi /etc/init.d/rc.shutdown".
    2. Pressed "i" on keyboard.
    3. Look for "#swapoff" and pasted theses lines after that line:
    /sbin/telnetd
    /bin/sh
    1. Pressed ESC-key and then typed and ran ":wq".
    2. Run "poweroff"  in the shell
    3. Closed Putty.
    4. Opened Putty once again, using the same IP and Port, but select "Telnet" instead of "SSH" as Connection type. A new command window opened and I had to login as "root" again.
    5. Pasted and ran "umount /i-data/sysvol"
    Now try "resize2fs" for all logical volumes from above until you find a ogical volume to expand. Copy the volume names from above.
    ~ # resize2fs /dev/vg_a246bbf1/lv_d648b119
    resize2fs 1.42.12 (29-Aug-2014)
    The filesystem can be resize to 525860864 blocks.chk_expansible=0
    Resizing the filesystem on /dev/vg_a246bbf1/lv_d648b119 to 525860864 (4k) blocks.
    The filesystem on /dev/vg_a246bbf1/lv_d648b119 is now 525860864 (4k) blocks long.
    ~ # resize2fs /dev/vg_a246bbf1/lv_a4b19a90
    The filesystem is already 450883584 (4k) blocks long.  Nothing to do!
    ~ # resize2fs /dev/vg_a246bbf1/lv_067dd4d6
    The filesystem is already 524812288 (4k) blocks long.  Nothing to do!
    Rebbot the NAS by pressing the "poweroff" button on the device.
    Vola. You are done. The volume should be expanded.
