NAS 326 fan speed
Duplex
Duplex Posts: 3
image  Freshman Member
Hi
Could someone direct me to the thread for fan speed on these things please i couldn't find one and cant believe no one else has asked this as the fan speed turns at max revolution and is way too loud and unnecessary, i have swapped out the fan and its still the same, How do i make the fan speed less by command line please. I cant use it because of this.
  • Duplex
    Duplex Posts: 3
    well after research apparently not by software as it 3 pin only. probably have to solder a resistor or something in to lower the voltage to it
  • Mijzelf
    Mijzelf Posts: 3,079
    image  Guru Member
    3 wires is enough for software regulation. 1 ground, 1 pwm and 1 index. Problem is that I never has a 326 in my hands, so I couldn't study the way the fan is regulated.
    On the 310 it's a daemon in userspace, on all other NSA3xx models you could only read the rpm, but the fan speed was regulated by some microcontroller.
    On the 500 series it is a daemon in userspace, which can be tweaked, but for the NAS326 I don't know.
  • zemciko
    zemciko Posts: 7
    Looks weird to me. I have 2 different 326 and both are very quiet. If i can hear something, then its harddrive not fan ...
  • Duplex
    Duplex Posts: 3
    Hi Mijzelf,
    thanks you very much for your response, let me work from your provided info and report back if any success :)
    Regards
