NAS 326 Problem with GLAN
Milkinson
Hello. I have a problem with connection NAS 326. I am using this nas several years for backup my files, but now I wanted use this NAS for movies. I find out that I have only 100mbps (I see it in nas options) How to get GLAN? I tried everything.. connection via cabel Cat6 and Cat 5e. I use switch with Glan, router with Glan all without some improve. Last experiment, I connected Nas to PC (without router) I used static IP but NAS still shows only 100mbps. I have the last firmware. Where is problem? can be damage on lan board?
Certainly possible. As you may know you need an 8 wire cable for gigabit. When you use a 4 wire cable the connection will fall down to 100 Mbit. When the connector in the box has a faulty pin, or there is a problem with the traces from the connector upstream, it will have the effect of a 4 wire cable.Milkinson said:can be damage on lan board?
Is there any differences between led color for 100/1000
- 244 Nebula Ideas
- 6.9K Security
- 807 USG FLEX H Series
- 392 Security Ideas
- 88 Switch Ideas
- 60 Wireless Ideas
- 7.3K Consumer Product
- 333 Service & License
- 540 News and Release
- 106 Security Advisories
- 5.5K FAQ
- 89 About Community
- 124 Security Highlight
