[NEBULA] Unblocking clients
Hi, I have blocked a client over 2 months ago and now would like to unblock it. The problem is that in the list of clients I have only find the last 7 days, so I cannot find this client to be able to unblock. Could someone please let me know how to do this?
Hi @akyn2u,
It's a limitation of spec. about free organization, however, you can use Nebula APP to check the blocked clients and unblock it by editing the client.
BTW, there's a known issue of the APP about blocked clients on Android and going to fix in the end of this month, so please use iOS to edit the client page for now.
Thanks.0 -
-1 -
Unfortunately, in the list of clients I can only see the current ones, but not the old blocked one. I was using Android, so should I try iPhone?0
Hi @akyn2u ,
As previous reply, there's a known issue on Android device to check blocked clients, and this issue will be fixed at the end of this month.
Please check the blocked clients via a iOS device with Nebula APP.
Thanks.0 -
I have just checked on iPhone and cannot list all blocked clients. How to get there? I clicked on the homepage on APs and it only gives me the list of current clients. Thanks.0
Hi @akyn2u,
As our discussion about this issue, the client was not blocked by the AP but usually can't connect. We found that log for client, Microsoft Surface Book, didn't send "authorize" as standard but only "associate". As the Microsoft official suggestion is to reboot the Microsoft Surface Book for resolving this issue.
Hope it's helpful.
The answer is helpful, but rebooting doesn't work. Will request Microsoft to look into this.1
Hi
You can check for Archived/Inactive Lists because some platforms might have separate sections for archived or inactive clients. Explore your platform's settings to see if there's a section where older blocked clients might be listed and if it allows you to manage them from there.
- 435 Beta Program
- 176 Nebula Ideas
- 428 USG FLEX H Series
- 298 Security Ideas
- 79 Switch Ideas
- 274 Service & License
- 422 News and Release
- 89 Security Highlight
