IPsec VPN problem
Hi guys,
Just a quick question. We have one VPN gateway used by 2 phases 2 on a USG40W as we have on many other router without any problem.
On this one, for an unknown reason, phase 2 are never connected both at the same time, there are dropping all the time, sometime we can ping through these phase 2 but it is very unstable.
I tried with firewall off and it's still the same.
In the debbug logs, I notice some weird error regarding IPSec, why would IPSec drop packet ?
Thanks for help,
Davy
IPSec Dropping packet. ret=1, step=11 IPSecSPI: 0x0 (0) SEQ: 0x0 (0) No rule found, Dropping TCP packet. ret=1, step=11 IPSec Dropping packet. ret=1, step=11 IPSec SPI: 0x0 (0) SEQ: 0x0 (0) No rule found, Dropping UDP packet. ret=1, step=11
@IT_Field_Support,
I've applied your configuration file to USG40W to run the test.
The test result is sent to you in the private message.
Hello ,
On zyxel wal usg50 getting this erroIPSec SPI: 0x0 (0) SEQ: 0x0 (0) No rule found, Dropping UDP packet. ret=1, step=11 any help? Thanks
Hi @Irfan,
What is the model of the remote site of VPN tunnel?
Could you share startup-config.conf of USG50 and topology with me in private message?
Ok thanks , now i upgrade USG50 with latest firmware which you sent me..
Than let you know.
Thanks0
- 588 USG FLEX H Series
- 477 News and Release
