USG40W Fails to update signatures
CRU_Technologies
USG40W with current subscription, hasn't been updating, if I run Update Now 'AV Signature Update Has Failed (failed)'
Why?
Why?
Did you try to enter another dns server like google's 8.8.8.8??
I have met this situation before......and the symptom seems resolved by:
Router# debug service-register erase _token
Is your firewall behind another router/NAT?
I got the same issue before.
In my case, the root cause is that the bandwidth of WAN is insuffient.
After BWM rule is modified, signature update is successful.0 -
Hello CRU_Technologies,
After the follow above advises(release token and check DNS server), is the issue solved?
Charlie0
- 222 Nebula Ideas
- 617 USG FLEX H Series
- 53 Wireless Ideas
- 485 News and Release
