Dark Skin
Second point: an easier way to bind a mac address to a fixed ip inside the dhcp. it should be inside the client's tab, not only running through the dhcp tab
Yes, dark skin would be great.
I won't be using the beta untill then. All that white is just far too bright.0 -
Yes, Dark Skin is important, we come from Dark Nebula, we want see Dark Nebula again.
Many vendor launch Dark Mode recently:
WhatsAPP:
Please consider to add it.
I like the new design, but why change to white skin? We need a dark skin again thanks :D
I agree with Dark Mode.
Hi All,
We already have a plan for next year to let users choose if they want to join Nebula's (a.k.a Force) Bright or Dark side, and change side at anytime. ?
For the feature "Add static DHCP entry via NSG client page", we will put it in our future queue.
Thanks you guys for supporting Nebula!
2 -
Another thing, i've found pretty confusing understand where a client is connected to.
it says "Put a gateway here", but i'd wish better to see "i am coonected to switch Y port Z",and then maybe "managed by gateway X"
Hi @AleValent
Could you tell us where do you see that? If you could include a screenshot will be useful.
Thanks!
-Bayardo
Well.. i'd expect to know that my client is connected to the switch "X" at port "Y" so i can locate physically where it is. Also, i am noticing that there's not a clients tab in "site-wide" tab. Maybe (i would also ask to the others) it could be useful have a summary page.
Hi @AleValent
Thanks for your input! Currently the per device type (AP/SW/GW) client pages show the corresponding device (AP/SW/GW) to which the client is connecting. However, we understood your requirement and we are planning to add a combined client page in a future release.
Thanks again ?
Hey guys! I guess you already know but just to make it official here ?: The so wanted Dark skin has been released on last Monday!!! ?
Please take a look to it, hopefully you like it. There are few glitches that we are fixing, it will get better through time.
Cheers!
- 439 Beta Program
- 2.8K Nebula
- 202 Nebula Ideas
- 6.3K Security
- 516 USG FLEX H Series
- 328 Security Ideas
- 49 Wireless Ideas
- 289 Service & License
- 461 News and Release
- 4.3K FAQ
- 97 Security Highlight
