[NEBULA] IPSec VPN client not working?
In this new beta release came with IPSec VPN support. But i was not able to get it work with Zyxel own IPSec VPN client software. What made me wonder is that where is the place where i enter the phase 1 and 2 settings? I was only able the find them under the Site-to-site VPN section, but i need to have a IPSec Client working and under that section i don't see any option for phase settings.
Hopefully we get some fix/support for this issue quite soon?
Hello @Heikki
Welcome to the community!
Can you check the VPN client application proposal (IKEv1) setting has use 3DES, SHA-1 as like the below screenshot and please enable X-auth,mode config as well.
Also don't forget to create the VPN user at Organization>Cloud auth. in Nebula control center.?
Hi Chris. Is there a possible you to take a teamviewer session and we could quickly go this through?
-Heikki
Will PM you, please check the inbox message.
/Chris
Update this post has been handle via eITS channel, for everyone who doesn't know how to configure IPSec VPN client can refer to this Link in FAQ?
- 222 Nebula Ideas
- 617 USG FLEX H Series
- 53 Wireless Ideas
- 485 News and Release
