[NEBULA] Trouble when adding AP to Nebula
dgoguet
dgoguet Posts: 2  Freshman Member
edited April 2021 in Nebula
I bought 4 NWA1123-AC Pro to cover my building.
The AP work well when in standalone mode, but as soon as I add them to Nebula by registering the S/N and MAC, they stop working (power green, Nebula connexion orange blinking)... Any Idea?
Thansk in advance!
  • Zyxel_Freda
    Zyxel_Freda Posts: 397  Zyxel Employee
    25 Answers First Comment Friend Collector Third Anniversary
    edited November 2019
    Hi @dgoguet,
    When you registered the AP to Nebula, the AP will connect to Nebula and transfer mode from standalone to cloud. The LED shows blinking amber when connecting to NCC. Please keep TCP port 6667/4335 and UDP port 123 unblocked by firewall for AP and NCC connection. It takes about 5-10 minutes to transfer the mode and sync configuration on Nebula.
    Thanks.
  • dgoguet
    Thanks for your answer @Nebula_Freda .
    The firewall administrator is asking me some extra informations to avoid security risks:
    • Do the ports need all to be opened in both ways (in and out traffic)?
    • What is the IP adress or FQDN of the cloud service contacted by the AP's?
    Thanks in advance!
  • Zyxel_Freda
    Hi @dgoguet,
    Besides Alfonso's information, here are two more information for you.
    TCP 4335/6667: Both ports used for device netconf connection and management to Nebula Control Center.
    FQDN:
    s.nebula.zyxel.com - For Nebula Cloud Management
    *.pool.ntp.org - Network Time protocol
    You can check detail information in HELP> Firewall information.
    Thanks.
  • 1123user
    1123user Posts: 6
    i am managing hundreds of NWA1123v2. the APs randomly lost connection to nebula, the current workaround is to hard reset the AP and it works for few days and will be disconnected again.
    what seems to be the problem?
Nebula Tips & Tricks
