USG60W - WAN1/2 link speed
Hi Zyxel community,
is there a official document, about the link speed for WAN1/WAN2 at a USG60W ?
i've connected the USG60W directly to my INAC (InterNet Access Connect) Firewall with Intel GBit Ports, but USG show only 100 Mbit ? is 100 Mbit correct by ZyXEL ?
Thanks an Regards
Christian
Hi @ChristianG,
Go to CONFIGURATION > Network > Interface > Port > Port Configuration and select 1000Mbps-Full Duplex on this port.
Connect wan1 directly to INAC Firewall again and check if the status of P1 is 1000M/Full.
Hi @Zyxel_Emily
thanks for your quick response. The Option Port is not visible on a USG60W [v4.32-WK52) ?
is this onyl visible in a newer firmware version for USG60W ?
Regards
Christian
Hi @ChristianG,
Yes. It is new GUI enhancement in firmware 4.35.
You can find this enhancement on page 22 of the release note.
- 435 Beta Program
- 176 Nebula Ideas
- 426 USG FLEX H Series
- 298 Security Ideas
- 274 Service & License
- 419 News and Release
- 89 Security Highlight
